John, I've been a little pre-occupied with guests and garden work, but this morning an nipped downstairs and grovelled under the car to take a few photos of the set-up on ours.
As you know, we have poly bushes and I am able, when the cam bolt is fully tightened, to "swing strut rods down out of the way (as I did when we were removing the diff etc), with relative ease. But, touch wood, I have never had issues with the cams moving once set, so I wanted to remind myself of what I had!
This is the right side strut rod cam, from the rear of the car, the bolt correctly coming from front to back, with the "loose" cam washer, lock washer and nut all at the rear:
There is nothing between the "loose" cam washer and the bracket. And, the lock washer is a fairly simple "spring" type, albeit, a fairly hefty one. The loose cam washer has a "half-moon" inset in the hole, which locks into the slot on the bolt.
This the front end of the bolt (the other side of the car in this case as the heat shield is in the way on the right side):
Again, nothing between the cam face and the bracket.
I bought a "fancy" six point ring spanner when we tackled the strut rod bushes back in about 1992(!) and I continued to use that, although I do now have nice six point deep sockets.
As i mentioned, I did put the car on ramps to tighten the cam bolts in the early days, but now, as the rods clearly are free to move when the bolt is tight, I have tightened them with the car on axle stands or the Quick-Jack.
You may well have this all sorted now, but I thought it may help a little to see another car's set-up.
