Hi Johng
Multi ways to make your own diag smoker
Here is a real cheap way, all types need a air source to make low pressure
Here is a way using a tool to flush brake fluid lines
This has a hand pump to create air pressure, or you see I installed a valve stem to instead use an air compressor with regulator to adjust PSI I want
I prefer and made mine using a small car or kitchen fire extinguisher, ( I thought this up while having a wet dream
I empty it, then flush it
Parts I used (also for brake unit above)
1. any auto parts store would sell GM glow plugs, this will be the heater
2. to prevent getting too hot I used a 12 volt turn signal flasher, this will auto cycle on/off, so the glow plug never gets too hot
but enough to cause oil to smoke
3. 12 volts on/off switch
4. wires
5. wiring clips to connect to a battery
6. wheel valve stem, to connect air source to flow through the smoker
7. hose to connect to the output of the fire extinguisher
8, steel pad, like what is used when painting, like a Brillo pad.
This acts like a wick and draws fluid up from bottom to top of pad where glow plug is
9. could use like baby oil or auto tranny fluid
Fill bottom of fire extinguisher with the steel pad
Drill a hole so the glowplug is sitting just below the pad , do what is needed to mount and seal the glowplug
Wiring,
Black wire from ground side of the battery to lug you mount to the extinguisher (glow plug needs it)
Red wire from battery, othe end mount single pole on/off switch
Other side of switch to turn signal flasher
Other side of flasher to glowplug,
Mount the valve stem up high, to generate the extinguisher under pressure
Fill your oil so it is lower than glowplug
Try at first like 2 PSI air pressure
Jack up vehicle with jack stands
Consider what the lighting is to assure being able to see the smoke
Whatever oil you use smell that smoke so you know it when you smell it as the leak can be small and not seeing
the smoke but can smell about where it is coming from
Stuff exhaust tips tightly with rags to seal well
Prop butterfly of in your case the carb, insert output smoker hose and seal carb with rags, etc to seal
Shake extinguisher to assure oil is soaked the steel pad
Connect to your battery, turn PSI flow on, turn switch on.
Now very closely examine and look (
like this
for direction of smoke or smell oil
Questions ?
Ask
If need be increase air pressure to like 5 PSI
Turnsignal flasher will be clicking as it contacts heats up, opens circuit, cools off closes circuit
