That is interesting johng, did you have any symptoms or just the mot readings? My 72 has a bung to access the exhaust flow, but was set up in buffalo NY and altitude my be different to cornwall.It's been a while, but thought I'd give an update on the Air Fuel Ratio situation. My lovely wife bought me a wideband sensor kit for my birthday and I've had a bung welded into the exhaust.
The surprising result was that I found the car was running a bit rich at idle, which gradually leaned out as you increase revs up to 2000rpm and then shot up to 17.5:1
The value that was measured at the MOT station was actually in terms of lambda (it was a value of 1.22), I'd multiplied this by 14.7 to get an AFR of 18:1. I realize now that was wrong, because the value of 14.7 is for pure petrol. For the E5 that I'm using it should be 14.4 and that makes the MOT measurement an AFR of 17.6:1. Basically, the MOT station measurement was correct all along!
Taking the car for a drive it was running at 17.5:1 whilst cruising anywhere from 45 to 60mph, hopefully I haven't done the exhaust valves any damage.
It was simple to fix the idle mixture, just needed to go from 4.5 turns out to 3.5 turns out and also it was easy to fix the cruise mixture as well. On my carb you can adjust the Adjustable Part Throttle from outside of the carb and winding this up brought the cruise AFR down to 14.3.
Here are the results I ended up with.
One other little job that seems to work well was for my Air Con. The air box that houses the evaporator is very close to my headers and gets too hot to touch, which can't do much good for the cold air inside it. I've now covered the box with some self adhesive aluminised fiberglass sheet. Now the box doesn't get hot at all and the air con seems to work much better (although maybe that just because it's not very hot out now).
Mine has always smelt a bit rich so maybe i should find a holley carb guy and have a tune
