The lower block was cleaning up pretty good though! And didn’t look half as bad as I expected it too. Some miner pitting from corrosion on the piston heads and bore surfaces so the block will need pulling but it’s repairable, which is great news because I wanted to keep the original engine.
I now started to strip out the cooling system, the radiator and anything else in the way so I could get to the timing chain and cam which both looked great! I’ll be swapping these out for something with a little more power anyway but it was still good to see damage had not gotten to far into the block.
But not everything was going so smoothly, removing the pulley my crank shaft bolt snapped clean off! One of them famous 2 minuet jobs that become a 2 week job!
for days I had to go at this bolt with drill bits until finally it spun out!
That feeling!!!
Well at this point and for now I’ve gone as far as my funds and skills learnt, will take me with the engine! She’s was put on the back burner for the rest of 2021.
However I still had plenty on the car I could crack on with….
