Continuing on with reinstalling the electrical system and gauges.... I am currently working on the centre dials and started with what I thought would be an easy one - the clock.
It was no surprise that it wasn't working but what was surprising was the way that it works. I knew it wasn't a quartz style clock but thought it might be an electric motor running through some gears to work the hands. However on removing the cover there is a full mechanical clock - a solenoid pulls a lever that winds up the mainspring with just under a minutes worth of power. It has a balance wheel with escapement etc with a gear set to move the hands.. When the mainspring is nearly spent it reconnects the solenoid which fires, winding up the mainspring again ad infinitum.
I spent a little time cleaning some of the gears and adding a very light machine oil to some of the bearings and it started to come to life: running for a few seconds and then needing a 'push'. It then progressively ran for longer and longer. I hope to run it overnight before putting it all back together.
For those that are interested - here's a video of its operation. The solenoid is at the centre bottom and you will see this trigger about 32 seconds in.
'72 C3 Clock Mechanism
