Cool!Always liked the look of the factory Ford A/C as fitted to the first Generation mustangs. Fitted under the dash centre and the half centre console set it off nicely. Even looked good without the console.
This unit was fitted to my 57 Thunderbird when it was being restored. Looked real nice.
View attachment 28166View attachment 28167
What brand of hydraulic lift did you have? I'm still contemplating one of them, but I don't work under my cars that often, so justification of the cost etc. Headroom in the garage, I think I should be able to fit the 4 poster like you have...... except for the normal up and over garage door I have means I'll have to remember not to open the garage door when the Corvette is in the airBefore I used this air over hydraulic lift which is also great and very sturdy if you have limited headroom as I did in my previous garage.
Never have got round to getting my AC up and running as not a priority job as the UK rarely gets hot enough . Usually have the window down or the T Tops out .Corvettes really do get cool inside with a fully functioning A/C system, as it’s a small area inside to cool down. Especially on 68-77 coupes without the large rear window.
TBH I haven't used my Vette too much this year.......but generally once the weather is hot enough to remove the T roofs an rear window they'll usually remain off for the rest of the season. But I havn't removed them this year.Never have got round to getting my AC up and running as not a priority job as the UK rarely gets hot enough . Usually have the window down or the T Tops out .![]()
You have been denying the `great unwashed ` the pleasure of seeing your superb beast out on the road Ross . Must try harder next year !TBH I haven't used my Vette too much this year.......but generally once the weather is hot enough to remove the T roofs an rear window they'll usually remain off for the rest of the season. But I havn't removed them this year.
That is the plan.......You have been denying the `great unwashed ` the pleasure of seeing your superb beast out on the road Ross . Must try harder next year !![]()
Can't recall the manufacturer Captain but I still have it so will check soon. I think it was £1,100.00. To get maximum use out of a lift 12' minimum but ideally 14'What brand of hydraulic lift did you have? I'm still contemplating one of them, but I don't work under my cars that often, so justification of the cost etc. Headroom in the garage, I think I should be able to fit the 4 poster like you have...... except for the normal up and over garage door I have means I'll have to remember not to open the garage door when the Corvette is in the air(its a double garage, so can open the other side's door if coming from the front, or the back door if coming from garden).
Don't like to jump on a post like this but be very cautious of the above vehicle lift.My 396 has that type fitted and still blows very cold. I was told by the PO it was fitted by the dealer before the first owner collected their brand new Corvette
As it is sold as a "parking lift" it most likely doesn't meet the build standard (BS EN 1493) of a vehicle lift.
They are being imported from China and are usually cheap, compared to a vehicle lift.
One of the main points that "parking lifts" do not always have is a method or device to prevent uncontrolled movement, in layman's terms if something goes wrong the load bed drops to the floor with nothing to stop it.
Under no circumstances should you ever walk under a car lifted by one, let alone work on a car on one.
Noted Steven and having some experience, I've given Dave a list of questions to ask the supplier. When we worked on mine last weekend, I showed them the cam locks and impressed on them not to go under the lift until all 4 were checked and engagedDon't like to jump on a post like this but be very cautious of the above vehicle lift.
Don’t you just love paying someone to do a job then end up putting it right yourselfThat being said, the installers or as I like to call them - lazy bastards convinced me it didn't need bolting to the floor and I said, ok fine.. The first time I used it the posts all moved however slightly but it threw the whole thing outta whack. I then bolted it down myself and squared it up as it should be.
