So about a month ago I was stupid enough to say that now "I just need to get it filled with gas"!
I did get it filled with gas but the system didn't produce much the way of cold air, the compressor got very hot indeed and the pressures were not what as expected. My friendly aircon man thought it looked like there was a blockage somewhere and after a bit of inspection, we found it. The hose connection to the top of the condenser is very difficult to get to without removing the bonnet (if I ever do this again I will remove the bonnet). Without realising it, whilst tightening this joint I had managed to twist the condenser inlet pipe and severely restrict the flow through it
. Whilst discussing things we also realised that there didn't appear to be any high pressure cut out in the system. The old compressor had what looked like a pressure relief valve, but the new one just appeared to have a blanking plug and this wasn't the same thread as the relief valve from the old compressor. At this point I decided to give up whilst I investigated how to build some sort of over pressure protection into the system and see if the condenser was salvageable.
It was easy to un-twist the condenser inlet pipe, which looked like it would then allow a proper flow through it, although to what extent this has weakened it I can't be sure!
I contacted the compressor manufacturer who were very helpful and told me that what I thought was a blanking plug was in fact a relief valve, but it's set to blow at 500psi and at this point it actually ruptures the thin outer skin. This is the relief valve
I decided I could do with some better protection than this and found a binary switch to replace the existing pressure switch (which cuts out the compressor if the gas pressure drops below about 30psi). The binary switch also does this, but also cuts out the compressor if the pressure goes above 380psi (still high but not so high as the relief valve and it resets itself). The problem with this was that the switch has a female thread of 7/16unf x 20tpi and the port on the car was 3/8unf x 24tpi, so I needed a thread adapter. After a lot of searching I found this one
Brass Union 7/16" UNF MALE to 3/8" UNF Female The next problem was how to make it seal properly. This required drilling out appropriate sized holes in both ends of the brass union to allow the o rings to fit. Having done this I checked that the whole system still held a vacuum and finally today took it back to "just have it filled with gas"
The good news is that it now produces nice cold air. At a high tickover the high pressure side is around 200psi and the low pressure side is around 40psi and so far nothing has leaked!! The only bad news is the drive belt is chirping a bit so I need to try tightening it up. Oh also I want to put some insulation around the cold inlet to the evaporator, as it's conveniently positioned close to the nice hot exhaust manifold
