Reminds me of days being stuck under boats for days sanding and painting them, i sooooo dont miss that.
I googled for the paint but not able to find any for sale, but for stove paint. which ,may well be the same or similar as the code P0027 come up on there website.
Anyway i have once again degreased and cleaned back the front end of the chassis. So this weekend i will give a paint if its dry enough. Ill use the paint i have. its good stuff but a pain to apply really. I have some of the Rust preventative lef, not much but maybe enough, but plenty of the direct to metal. Either way job will be done so then i can start to put it all back together again and get it down back on its wheels.
Anyway. other stuff
After cleaning up the starter motor i noticed this
I was tempted to repair it, and then thought sod it buy a new one.
Then i decided to fettle it. Ill get a shorter bolt and fit that to a flattened out flange once i finish it and bolt through the bottom flange only. It may work it may not. But why not try as i can still get access to the bolt.
I have started to grind back the flange for a good flat surface for the bolt head to sit against.
