Ok after a bit of advice and research here is a shopping list
Cant decide on a clutch yet.
Shopping Cart - JEGS High Performance
www.jegs.com
If buying that set of heads better do it soon as it states only 1 set left in stock
What about pushrods, and rockers ?
New bolts for heads, intake and headers
Also heads, intake, header, and carb gaskets
and gasket if needed for belling housing, new pilot bushing for flywheel. New U-joints for driveshaft
You have a tool like shows on Jegs to pull out and insert the CAM correctly ?
Or a CAM degree wheel, so knowing if installing CAM straight up, or you're degreeing it ?
Lube to use on CAM when installing
I can see you mean business wanio! Got stuck in there straight away, did you get caught out without the plastic bag over the gearbox tailshaft housing to catch that verrry smellly oilAll i am trying to work out is the kit to get. All the other bits are easy to work out what buy.
I have seen these heads and also been told these will be good or better / livelier for a street car, more if i swap the 2.72 diff for a 3.73. but thats a future thing. I just wnat to get all the gear together for a couple week off this Christmas and get stuck in.
ProMaxx Performance 9183: 183 Series Aluminum Cylinder Heads Small Block Chevy Straight Plug - JEGS
Get the Best Performance with ProMaxx Performance 183 Series Aluminum Cylinder Heads Small Block Chevy Straight Plug 9183 parts at JEGS. Shop Now at the Guaranteed Lowest Price!www.jegs.com
Speedmaster PCE281.2004: Cast Aluminum Cylinder Head Small Block Chevy 350 w/Hydraulic Flat Tappet Cam - JEGS
Chevy SBC 350 190cc 64cc Straight Hydr-FT Complete Aluminum Cylinder Headswww.jegs.com
A real industrial set up you have there , grit blaster cabinet and all ! Very impressive .View attachment 28045
run with these
Oh yes i did this with the Ally Oxide when i first tried the cabinet out the other week.
Carb came up not to bad. could be better but its cleaned up ok. Looks good in the dust hey haha
This weekend ill stick hen in the cleaner, although the lock switches have loosed up nice with a soak in WD40. But ill have split the switch panel from the window switches and ill add then to the cleaner aswell. Its a good size cleaner so i want to not waste the anything.
It looks like the passenger side door panel hasnt been removed much as this is what i found once it was removed. all the other plastic sheet had fell off. in better nick than me and its near as old as me/
i removed the oil pan, dont know why but i did while i was cleaning the block up. AND found it s 4 boltThen i was told most/all crate Goodwrench engines are 4 bolt. still not a bad thing.
Need a new sump gasket now as the ones i have are single dipstick. No rush though so ill sort one later. Found a couple places to get one from. But i probably get one with the other bits i know ill need in a couple months on my new shopping list.
And last of all i think, i started on polishing up the wheels
comes up ok i reckon.
Thanks but not Industrial just hobby gear really. Inexpensive towards Industrial. Does the job though.A real industrial set up you have there , grit blaster cabinet and all ! Very impressive .![]()
Still an impressive set up for hobby gear Waynio and lucky to have it all on your doorstep . But I can`t complain thoughThanks but not Industrial just hobby gear really. Inexpensive towards Industrial. Does the job though.
Forgot the lathe and milling machine !!View attachment 28059
